Help please - cost of running pond filter/pump
Not wishing to contradict the Don.... (or his boys:()Are you sure about that? seems a bit steep to me? ?:|
Electricity is sold by the Kilowatt/Hour.
For 1kWh the 11watt pump would run for 1000/11 = 90.9hours.
in a year there are 365*24 = 8760hours.
so during a year this pump would use 8760/90.9 = 96.4 kWh (approx)
So we will have to buy 96.4 units of electricity....
which do actually vary dependant upon how much you use..
e.g. so many units charged @ higher rate then drops to lower rate. (this can be checked off you bill)
typically these are around 10p & 17p {give or take +/-2p}
so for example at the higher rate....
96.4 units * 17p =
Clearly the Don has miscalculated here, removing my boys Taxes, gives a more realistic price.(As indicated by SL)
Don
So thats how your boys can always afford to dress so smart! ;)
I heard they have a new, "finest Italian cut", suit every day!
even when diggin to bury a SWA .......
& probably a couple of body bags! :eek:
:D :D:D:^O:^O:^O
