help pls??
amcevoy
Mar 30, 2009
2
Im doing my 2330 l2 practical next wk and have to wire up 2 2way switches with 2 lights and draw a circuit diagram of this before i wire it up. I understand how 2 way swiching works with 1 light but not with 2 lights can anyone explain? what would the circuit diagram look like?
Andrew
Hi i completed my 2330 practical in march its easy, from light 1 to light 2 its Live to Live, Neutral to Neutral then go from you loop in your first light to L1 in switch 1 and your switch wire in L2, then from SW1 common to SW2 common an L1 to L2, L2 to L1 it doesn't matter which way you put your L1, L2as they are all live don't forget to check polarity when doing continuity by flicking the switch also don't forget to check the strappers on you insulation test also by flicking the switch, hope all goes well for you.
