Hi, I'm new to solar PV and thought the best way to learn is joining a forum. I've been considering solar for the past 12 month and now I have the funds I have started purchasing items o would need.
Location. I have a STD 1930s 3 bed semi. In my garden I have 2 outbuildings. One 140 block garage 32ft X 10ft and a workshop 20ft X 20ft Alos built from 140 blocks. These form a L shape approx 40ft from my house. Roof is corrugated tin and it's south facing.
Armoured cable runs to the garage from my house consumer unit. Into a garage cu.
I have just received 15 new renesola jc255m panels. Each panel is 255w 37.5ov and 8.8ah
I have also just purchased the renusol mounting kit for the above panels. I plan to mount them 3 wide X 5 deep (15 panels) on the garage section of the roof.
Theses will go to the Solis 3.6k-48es hybrid inverter.
Question I have is. I plan to run the panels in series.
Which is best.
3x5 panels. (One I was going to use)
5x3 panels.
2x7 panels. (Only use 14 panels)
Does it make a difference?
Also The Solis inverter accepts 2 string inlets from the solor panels. Should I use both or just one?
Tbh I have loads of questions.
Which is best.
5x3 panels.
