Help with my setup
Andy1733
Apr 26, 2022
89
16
I'd like to know why we even need one if we have a smart meter that reads export?
One seems to make sense for the no longer available FIT payments where I believe there was a generation element to the payment. But new installs haven't been able to get that for ages.
My installer put mine between AC Grid and the CU.
I believe that the backup outlet is for running an up to 3.5 kw feed that supports important devices like fridges, from batteries, in the event if a power cut.
Thanks m8. My electrition said it goes there but we were both unsure about the backup. If it needed a meter also.
binky
eco warrior......™
May 7, 2008
11,681
528
Sunny Plymouth
Mostly generation meters are installed as a hangover from the days of FiT, there really isn't any need for them. I still install them in hope some form of FiT returns - did I just see a flying pig 🐷😄
Andy1733
Apr 26, 2022
89
16
Do you think it's not worth bothering? Would the dno want one fitting?
Andy1733
Apr 26, 2022
89
16
Were just filling in the g98 for for northern power grid.
There's a section that says summary details of micro generator where multiple micro generator will exists within one premise. Do I fill this section in of I'm using a single inverter
Image attached
Andy1733
Apr 26, 2022
89
16
A mate of mine was clearing his garage and knowing I've just fitted solar asked if a hosola 2200 grid tied inverter was any good to me. He was skipping it of not. Having just fitted the op system. Is there anything I could do with this inverter? Is it worth bothering setting up with its own panels or would it not generate enough to warrant the install?
