Hi I have recently moved into a new flat and looking for help regarding hot water please
In my old flat i had a water tank in a cupboard and had a on/off switch on the wall, which i left on constantly so always had hot water, simple.
this new place is completely different, there is a water tank in the cupboard in the bathroom but no on n off switch. I am guessing it is meant to heat up over night but it doesnt, i get up in the mornings and have cold water/luke warm water.
The only way i can get hot water is to put the horstmann e7 bx box boost on which is in the hallway, but this is not cost effective as i worked it out the other morning. I put it on boost for 2 hours so i could get a bath and could see the smart meter going up and up during those two hours. in the 2 hrs it cost £1.26 to heat it up.
am i missing something here? is there a hidden switch somewhere or is the water tank not doing what it should be doing.
i have attached pics so hopefully one of you will be able to help me out,,
many thanks
many thanks
