Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Central Heating & Storage Heaters Forum
how immersion heaters work.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ProDave" data-source="post: 319298" data-attributes="member: 6969"><p>It's not two tanks, it's one tank.</p><p></p><p>the bottom heater will heat the whole tank, whereas the top one will only heat the top half.</p><p></p><p>If you are only using the top heater, you will find it a bit wanting, particularly if you like a nice hot deep bath.</p><p></p><p>If the plumber can't get the element out, it's time to bite the bullet and replace the tank. But do stick woth one that has two heaters in from the side like you have already, a lot less troublesome that top mounted elements.</p></blockquote><p></p>
[QUOTE="ProDave, post: 319298, member: 6969"] It's not two tanks, it's one tank. the bottom heater will heat the whole tank, whereas the top one will only heat the top half. If you are only using the top heater, you will find it a bit wanting, particularly if you like a nice hot deep bath. If the plumber can't get the element out, it's time to bite the bullet and replace the tank. But do stick woth one that has two heaters in from the side like you have already, a lot less troublesome that top mounted elements. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
