W
wabbitwabbit
Guest
OK chaps it goes like this...
Here and in the USA house prices are tumbling. If you have the 'balls' and can raise 50% deposit then very soon is the time to get over toe USA and buy up some of that property that you will be able to get very cheaply.
That is properties that are the result of foreclosures. Then rent them out, yes rent will be low t start off but then as the US economy recovers, which it will, watch your portfolio of property values go through the roof. Have to stat in the USA then get back over here and do the same here, we are about 2 years behind the storm that is hitting the USA.
My fees for the above advice is ONLY 10% of what you make
