Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Intruder, Fire, CCTV, Emg Light, Access Control
How to replace a PIR Motion Sensor?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="boltonsparky" data-source="post: 508186" data-attributes="member: 4678"><p>There'll be 6 wires in there. 12v + &amp; -, a tamper pair and an alarm pair. You need to power down the panel as there are some small fuses in the panel, if you just go at the cables in the sensor you'll most likely pop one of the fuses for the 12v power. Colours used can vary so you'd need to make a note of what cable is doing what in the sensor. They are small and can be fiddly. </p><p></p><p>Taking the cover off the sensor will trigger a tamper alarm if you haven't powered down the panel first. </p><p></p><p>If you get the identical sensor you can keep the sensor housing screwed to the wall or wherever and just swap out the board inside it. </p><p></p><p>Reassembling you need to make sure the sensor board and cover is seated properly as there are some micro switches for the tamper circuit. </p></blockquote><p></p>
[QUOTE="boltonsparky, post: 508186, member: 4678"] There'll be 6 wires in there. 12v + & -, a tamper pair and an alarm pair. You need to power down the panel as there are some small fuses in the panel, if you just go at the cables in the sensor you'll most likely pop one of the fuses for the 12v power. Colours used can vary so you'd need to make a note of what cable is doing what in the sensor. They are small and can be fiddly. Taking the cover off the sensor will trigger a tamper alarm if you haven't powered down the panel first. If you get the identical sensor you can keep the sensor housing screwed to the wall or wherever and just swap out the board inside it. Reassembling you need to make sure the sensor board and cover is seated properly as there are some micro switches for the tamper circuit. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
