Grendel
Active member
We have a Francis hydro turbine driving an asynchronous generator.
The wicket gates are manual and there is really no control.
We open the wicket gates, the turbine starts running and at approximate synchronous speed, we switch the generator on the grid. After that we keep the upper water level at setpoint by manually opening and closing the wicket gates.
Now because of difference in head and flow, the Francis has low efficiency outside design range, so we are in the process of removing the Francis and installing a Kaplan turbine.
The asynchronous generator will be replaced by a synchronous one.
I would like to install a PLC that controls the installation.
This PLC has input from water level at three points, frequency and current, wicket gate position and runner blade position.
I would like 2 modes of operation.
1) Grid tied
2) Island.
The PLC needs to be able to:
1) Start up the system.
2) Run the system grid tied and control the wicket gates to keep upper water level at set point.
3) Run Island mode and control the wicket gates to keep frequency at changing loads.
4) Run a flushing program in order to clear the turbine of debris.
5) In the future be able to start a grid cleaner when water level difference over the grid becomes too great.
6) Safely shut down the system in case of a fault or reverse current.
All in all not very complicated, but I am not familiar with programming PLC's and I have no idea what I need.
Would anybody here that is familiar with plc's be so kind as to help me out a bit?
It would be a great help if we could discuss the setup and sort out what I need.
Kind regards,
Hubert
1) Grid tied
2) Island.
Kind regards,
Hubert
