Yes, there should be a temp adjust control, this will be under the dome cover where the power flex enters..Is it possible to regulate the temperture on a pre 1976 Imersion heater? The water is near boiling!
anticlockwise to reduce temperature..Thank you all for your assistance. I've had a look and there is a screw in the centre of the plate but unfortunately there isn't any markings on it to show which way to adjust.Is it possible to buy a new top containing the elements and a thermostat and would it be compatable with with the pre 1976 drum? ?:|
Bet you turn it clockwise again come the winter.. ; \ :^O :^O:^O:^OThank you all again for your help. I have turned the screw anti-clockwise and the water temperature is now cooler-what a relief!!!!!!!!!!!!!
And it`ll fall off, roll across the floor, and drop down the gap between the carpet & skirting; lost for ever. :^O :^O:^O:^OBet you turn it clockwise again come the winter.. ; \ :^O :^O:^O:^O
A result, get the Champers out...Thank you all again for your help. I have turned the screw anti-clockwise and the water temperature is now cooler-what a relief!!!!!!!!!!!!!
