Is the following safe?
3m 1.5mm core into 3kw immersion heater? The heater is set on a timer switch to operate maximum 1 hour per day, seems to get a little warm as you'd expect. Are these timer switches a risk running at high load, there's a lot of crap on the market, any recommendation?
I see there are extension leads on the market with 2.5mm core, would I be better to get one of these and use the cable? Cheers
