Hi all. I said hello a few weeks ago and had a bunch of questions ready but seemed to get them answered via the search function, until now. I qualified at the end of 2008 and have finally got round to joining a scheme (assessment immenent) and have several jobs lined up. My neighbour called me in to look at his Immersion heater that has lost power to the switch and it looks like the original supply for it from the fuse has been redirected in the past to a SO :|
If I dig a bit deeper and this turns out right I'll probably put this into the main socket radial as a spur and free up the original fuse that`s marked I H ! I can then run a new supply to the I H switch. But... regarding RCD protection, the cable is only a short run (not in a wall) below floorboards and out in the airing cupboard, surface mounted in trunking. I know this route/method means that RCD protection is not required but what about the fact that the IH is in zone 2 (or is it?), reg. 701.411.3.3.
The shower in the en-suite is in the corner of the room and has a dummy stud wall on one side. The airing cupboard is at the other side of the stud wall. My confusion is because the I H is in the airing cupboard but is this officially part of the Special Location?
Any help much appreciated and apologies for the trilogy :coffee
Craig
Craig
