Consider a service partition for a shower/basin ensuite, accessible via use of a tool.
Services such as digital instant water heater (digital remote control), whale pump, yadda.
Seems obvious to stick the 45A isolator outside the service partition, on the wall outside Zone 2 - but walls soon get cluttered and grid ain't doing 45A. Pullcord is not to clients taste (this is a 20m2 ensuite, clear frameless).
So... why not stick an isolator within the service partition - as for an immersion within its cupboard?
The problem I have with this is reg 132.15.1.
The isolation point should be SUITABLY positioned and provided to PREVENT or REMOVE danger.
Suitable for who?
End-user wanting accessible 45A isolator - for what, heater also supplies the basin 24/7?
Maintenance fine with 45A isolator inside service partition? Indeed I think an IPx4 isolator in there is safer?
Best clutter job I've seen is SFCU & double socket above every unit in a packed all on one side of a long corridor kitchen. Better to have a few grid every so often, keeping within the 2m isolation rule.
Suitable for who?
