Insulation Resistance test
taffyg1409
Mar 26, 2008
3
When faced with a lighting circuit containing 20 transformers for 50mm dichroics, which comes through a contactor and has 2 last man out switches, how on earth do you perform an I R test successfully without the obvious iv'e left something connected low readings????
Do you really have to disconnect every single transfomer bypass all the swithes!!
This would take for ever on a commercial property with 25 lighting circuits all with the above and batten fittings.
Somebody tell me there is a simple soulution or i'm going to hang myself!!! :eek:
Regards
the doctor
Part P Doctor ™
Mar 1, 2008
580
yep.
test n-e and l-e. dont bother with l-n....
perfectly acceptable, and record "lim" in the l-n box:D
taffyg1409
Mar 26, 2008
3
Lim meaning? 'limited' - 'limitation' - ??? Is this acceptable by the NIC??
Many thanksB)
Flying Scotsman
Electrician
Feb 15, 2008
468
yes i would think it would be
hey welshy when are you putting the yes and no smilie on here :^O :^O
Flying Scotsman
Electrician
Feb 15, 2008
468
oh go on welshy let us have yes and no pppppppppplllllllllllllllllllllllleeeeeeeeeeeeeeeaaaaaaaaaaaaaaaaaaassssssssssssssssssseeeeeeeeeeeeeeeee we'll be your friend for life.
:^O :^O:^O:^O:^O:^O:^O:^O:^O
extension15
Distinguished Member
Feb 13, 2008
1,659
On the subject of L-N Insulation Resistance testing...
Where it is not possible, basic continuity checking with a ohmmeter to verify load resistance (of concealed equipment etc) and more importantly to check for a short circuit..
B)
steptoe
Feb 13, 2008
24,337
117
Gtr Manchester
whoa whoa whoa guys
you must test between LIVE conductors and EARTH
this means PHASE and NEUTRAL, they are both LIVE
join the phase and neutral conductors together(use a block connector)
and test between these and earth,
only testing one of them at a time can potentially produce a voltage on the other thus frying the transformers, you MUST keep them both at the same potential.
steptoe
Feb 13, 2008
24,337
117
Gtr Manchester
On the subject of L-N Insulation Resistance testing...Where it is not possible, basic continuity checking with a ohmmeter to verify load resistance (of concealed equipment etc) and more importantly to check for a short circuit..
B)
oh, and totally agree with this, its a good refernce for your own peace of mind,
:D
Feb 14, 2008
7,480
21
Cloud Cuckoo Land
whoa whoa whoa guysyou must test between LIVE conductors and EARTH
Yes, this is what GN3 states.
cheggers
Mar 24, 2008
198
It is a good idea to test at 250v before putting the full 500v down the cable
I always do this first it shows upm anything still connected before you damage it
