Insulation Resistance testing
SparkJ
Sep 4, 2008
90
Hi
I am trying to test insulation resistance on a light circuit consisting of seven fluorescent lights.
The circuit is in a garage connected to consumer unit that is driven from a consumer unit in the adjacent house.
I can
Mr Sworld
Electrical Technician
Mar 21, 2008
1,152
You can join L/N together and test to earth OR disconnect each fluorescent light inside and IR test normally.
Worth checking the lighting switch though if it seems to be doing nothing to help the IR test.
sirsparkabit
Mar 19, 2008
419
9
You can join L/N together and test to earth OR disconnect each fluorescent light inside and IR test normally.Worth checking the lighting switch though if it seems to be doing nothing to help the IR test.
Can't you just take out the starter and tube then I/R Test ?
Mr Sworld
Mar 21, 2008
1,152
If they are old flourescents then there will be a capacitor in there as well! Which also needs disconnection as it'll start charging from the DC test voltage.
sirsparkabit
Mar 19, 2008
419
9
Blushing wonder how many of those i have charged up!! :_| :p :D
sirsparkabit
Mar 19, 2008
419
9
651... looking at you diary! ]:) you didn't know I had a copy of that did you 'SSabit'????? ]:) ] :) ]:)
Friday may be posssible?
I have no Dairy spesh, like milk though:^O
Friday may be possible??
O.K i Will tell robinson crusoe.
651 i,m lost help:_| ; \ ; \
