Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
General Forums
Non-Electrical General Chat Area
Interesting head lamp / torch
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Richard-the-Ninth" data-source="post: 560334" data-attributes="member: 23472"><p>I figured that for the £2.60 it is (+shipping+vat) I would get one........</p><p></p><p>[ATTACH]17482[/ATTACH][ATTACH]17483[/ATTACH][ATTACH]17484[/ATTACH]</p><p></p><p>It has two lights, the "yellow strip" across the front, (Which is flexible) and the 2nd light is mounted on the side angled down (You can't adjust the angle)</p><p>Each light has three settings, 100%, 50%, 0%</p><p>You can't have them both on at the same time. </p><p>All light switching functions are via multiple presses of the same switch.</p><p>It does sense movement to control the light, but you can just turn off this feature</p><p></p><p>[ATTACH]17485[/ATTACH]</p><p>If the indicator light is red, it can not sense movement.</p><p></p><p>[ATTACH]17486[/ATTACH]</p><p>If the indicator is orange, it can sense movement.</p><p></p><p>Yes, technicaly its pointless as you can't see it, but it is still a feature.</p><p>It comes with a USB cable to charge it.</p><p>Duration will depend on which light is on and at what setting. </p><p>Yes, you can't use it all day, but then its a torch, not a work light.</p><p>It is also comfortable to wear.</p></blockquote><p></p>
[QUOTE="Richard-the-Ninth, post: 560334, member: 23472"] I figured that for the £2.60 it is (+shipping+vat) I would get one........ [ATTACH]17482[/ATTACH][ATTACH]17483[/ATTACH][ATTACH]17484[/ATTACH] It has two lights, the "yellow strip" across the front, (Which is flexible) and the 2nd light is mounted on the side angled down (You can't adjust the angle) Each light has three settings, 100%, 50%, 0% You can't have them both on at the same time. All light switching functions are via multiple presses of the same switch. It does sense movement to control the light, but you can just turn off this feature [ATTACH]17485[/ATTACH] If the indicator light is red, it can not sense movement. [ATTACH]17486[/ATTACH] If the indicator is orange, it can sense movement. Yes, technicaly its pointless as you can't see it, but it is still a feature. It comes with a USB cable to charge it. Duration will depend on which light is on and at what setting. Yes, you can't use it all day, but then its a torch, not a work light. It is also comfortable to wear. [/QUOTE]
Insert quotes…
Verification
Post reply
General Forums
