interlinked smoke alarms..
andson
Apr 16, 2008
24
hello all, i am installing two mains powered smoke alarms in my house, i have a spare 6 amp mcb i can use, so i will be coming off that. my question is, i have to use 3 core and cpc so i can interlink them, but where does the third cable go in my consumer unit? is the cable i need 6243y?
cheers andy...
Mar 6, 2008
1,086
Teesside
you would normally run from the consumer unit to the first smoke in twin and earth 1.0mm or 1.5mm, either would be fine, at the first smoke you would connect line and neutral and earth as per instructions the 3core and earth then would be joined at this point in each terminal, e.g. brown and brown, blue and black, the grey would fit by itself in the interconnecting terminal, connect the same at the second, third smoke and so on till all connected and thats pretty much it
Theorysparky
Domestic Electrician
Feb 18, 2008
4,233
If yr with the NIC dont forget the smoke certificate !!!!
like my mate does all the time:^O
SPECIAL LOCATION
Trailer Boy - Electrician.
Mar 28, 2008
13,633
317
Ditto that m8... :D
but dont forget also to stick a bit of tape or sleeve in the appropriate colour to identify the correct conductors of the 3-core
(e.g. 3-core has no neutral colours in it!) :)
Apr 13, 2008
70
Well if he says to use black conductor from 3 core as neutral then just this needs blue sleeving at each smoke.
Grey can be left as it is when used as the interlink and obviously cpc will need Yell/ green sleeving.
SPECIAL LOCATION
Mar 28, 2008
13,633
317
Well if he says to use black conductor from 3 core as neutral then just this needs blue sleeving at each smoke.Grey can be left as it is when used as the interlink and obviously cpc will need Yell/ green sleeving.
Here! Here! sir.
as you say the three core Brown/Black/Grey + CPC
is carrying Live neutral & interconnect wire...
On most smoke detectors I see the interconnect wire tends to be white or orange...
personally as well as the blue sleeve to identify the neutral conductor..
I also try & put some sleeving or tape to match the interconnect colour
So if DIY bob take the smoke down the colours match up for reconnection!
welshwizard
Honorary Life Member
Feb 12, 2008
1,657
-1
KME & Specs - I am afraid that I have some bad news for you Both. :(
Anyway - because you are both so interested - I will tell you.
It is looking likely that we will have to close the institute - due to lack of funding.
Good news - Maybe - is that the trustees of the institute - are looking to start negotiations with Steptoe, to have a purpose built unit in his yard - next to the stables.
:D
SPECIAL LOCATION
Mar 28, 2008
13,633
317
Anyway - because you are both so interested - I will tell you.It is looking likely that we will have to close the institute - due to lack of funding.
:D
It'll cause arguments over who can sleep by the horse??? :( :eek: :O:O] :)
welshwizard
Feb 12, 2008
1,657
-1
KME - Naturally. And if he asks nicely - they even stretch the budget to buy him a Dentist's chair.
2nd hand chair, of course.
:D
Anyway - Enough of this silly talk - I am off to bed.
G' Night.
