Been to check out an RCD that seems to trip for no reason in a log cabin (someones home). Split load board. Circuits on RCD are: Kitchen skts, Bedroom skts, all other skts, Cooker, Boiler/alarm, Shaver skt.
TNCS.
Main incomer from meter goes to an isolating switch in a barn, from the switch it is split into two, one goes to a two way board with RCD main switch for this barn, the other goes to the log cabin. One of the ways in this barn board also feeds another barn.
The feed from the isolator to the log cabin looks to be 6mm SWA. Clipped along side of this is the a 10mm earth cable. Both these travel approx 50Mts to the log cabin.
All circuits in log cabin test ok for IR.
Because of the tripping happening at any time I wondered if there was a problem with water getting into any outside lights, but the lights are not on RCD.
What is puzzling, is some weeks ago a lamp blew in the barn, which tripped the RCD in the log cabin. How can this happen?
My heads hurting thinking about this.
Have I missed someting simple?
Anyone any ideas please?
What has me puzzled is, some time ago
TNCS.
