H hughoap Junior Member Joined Sep 17, 2012 Messages 2 Reaction score 0 Sep 17, 2012 #1 does not switch light on until 10 mins after i press switch. batten type light possible remedy? can i fit a new double batten light in place of a single batten light? do you need to adjust any wiring? thanks
m4tty Scaredy cat™ Supporting Member Joined Feb 5, 2009 Messages 5,612 Reaction score 1 Sep 17, 2012 #2 New starter ?? Ballast playing up. It's a straight swap anyways
Andy™ ©Resident Geordie™ Supporting Member Joined Jan 1, 2009 Messages 30,737 Reaction score 1,450 Location S. Tyneside Sep 17, 2012 #3 new tube & starter will prob fix it
Marvo Gold Member Supporting Member Joined Sep 21, 2012 Messages 1,177 Reaction score 62 Location Africa (Deep South) Sep 21, 2012 #4 Check voltage especially if it's an inductive ballast. If okay I would just replace tubes and starters. You can replace a single fluorescent with a double using the same supply, no extra wiring is needed, just install, connect and you're a for away.
paul b b Well-known member Joined May 26, 2009 Messages 1,751 Reaction score 1 Location stuck between a firm pair of t*** Sep 21, 2012 #5 and if you do change the fitting, SAFELY ISOLATE THE CIRCUIT!
H hxsarge Well-known member Joined Apr 12, 2011 Messages 300 Reaction score 0 Sep 22, 2012 #6 Make sure it's the correct starter
