kitchen lights
dean mac
Jul 29, 2008
117
england
hi everybody i would like to ask if im adding extra lights to existing kitchen lights do these lights now after be rcd protected thanks in advance
Admin1
Forum Founder
Feb 6, 2008
10,278
-1
If they are burried <50mm - Yes.
dean mac
Jul 29, 2008
117
england
We will just add the few missing words from admins post!!! ;) :x his fingers are getting :z :z:z:z:z:z:z:z
If all your alterations are in the ceiling void... then most probably No RCD needed. ; \ :) ;)
they are but what about exsisting switch drop
Mar 28, 2008
13,618
296
Ah!
the old phrase comes out again..
"The wiring regulations BS7671 is NOT retropsective..."
Only your new work complies with current regs...
existing work that you are NOT touching stays compatible with the earlier version of regs that was current when it was originally installed. (unless of course you identify some really serious deviation from regs which is unsafe & would render your alterations unsafe!)
If you want to put an RCD in ... there is no reason why you can't... but you don't have to...
If you knew that the customer has more alterations that Will be involving buried cables in walls...
than may be beneficial to install RCD now if the customer so wished? :) ;)
dean mac
Jul 29, 2008
117
england
Ah!the old phrase comes out again..
that helps thanks mate
