training_spark
- Feb 14, 2010
- 54
- 0
hi
can anyone help me with the following questions please
1) an earth electrode resistance test has been carried out using an earth electrode tester, the following results were obtained 155, 157, 161 (ohms) determine the value of Ra to be recorded on the periodic inspection report, show all calculations.
Am i right in thinking that you add all three values and divide by 3?
2)maximum test current to be applied to a 300mA rcd?
100mA?
3)forumla for calculating CSA of a conductor when they give you the mili ohms value and length of the circuit
4)One year after the completion of the office extension, one of the luminaires in the office area requires replacing.
Before undertaking the replacement of the luminarie list three items that need to be considered.
5)testing radial circuits, (cpc tests, IR, polarity, zs at furthest point, any more ?
6)Ra I*N <50V anyone have some questions using rcd formulas?
Will post some more in a bit, cheers
100mA?
