Lath & plaster
jckent
Apr 6, 2008
66
Ok
I have always (and i mean always) , had hassle with poxy lath & plaster walls.
For mounting switches and sockets, I have tried all sort of methods of flush mounting, metal back box and wood either side, plaster board backboxes. etc etc etc etc.
Does anyone have a sure fire way of securely mounting flushed outlets in this poxy demon invented stuff?
M107
Billy-the-Kid
Feb 18, 2008
5,564
28
Berkshire
Fein multitool & deep drylining backbox is all I'll say .
steptoe
Feb 13, 2008
24,344
119
Gtr Manchester
expanding foam.....
not too much mind, and let it go off before you try fixing your box into it, it will use your hole cut out to expand into rather than try and burst the wall apart, then cut/gouge it out.
cheap/cheerful and simple, :) like me.
Mar 28, 2008
13,621
297
Normal sockets & switches most of the time I do with dry lining boxes...
need a decent cutting tools to get clean cuts around the box ..
pad saws tend to cause too much crumbling of the surrounding wall.
The swine comes IMHO with shaver socket needing 47mm box!
then I go metal with wood batten mounted down the sides of the box....
some decent ready mixed filler is handy as well...
to patch round any gaps..
e.g. Polycell "deep gap" filler.. drys quite solid cuz its drillable when set!
Admin1
Forum Founder
Feb 6, 2008
10,278
-1
expanding foam.....not too much mind, and let it go off before you try fixing your box into it, it will use your hole cut out to expand into rather than try and burst the wall apart, then cut/gouge it out.
That sounds a good method, Steps.
steptoe
Feb 13, 2008
24,344
119
Gtr Manchester
seems to work fine for me admin, tho im not sure of the effect of the foam on T&E so i usually try put a little piece of 20mm pvc conduit in, or just dig a little clearance hole out. never had any probs yet tho, and i been back to a few jobs i did when i learned this as an apprentice a lonnnnnng time ago.
mind you, i dont think it was called ex foam then, and it deffo wasnt as widely available......
Admin1
Forum Founder
Feb 6, 2008
10,278
-1
Yes Mr Steps, Sir. That thought did cross my mind with regards to the Insulation and Pvc.
But - like yourself, thought of those was to overcome it. :)
baldelectrician
Mar 22, 2008
180
Cut out with a jigsaw or really sharp padsaw- drilling each corner
I try and fix one side of the box to a batten and use nice flanges (the ones that clip on yo the metal boxes) to hold the rest in (metal box)
Otherwise I use a extra deep fastafix and screw one dise to the batten
ianmacd
Mar 15, 2009
3,885
Go easy on him then as he is a mate ;)
Ian.
green-hornet
Distinguished Member
Feb 25, 2009
3,748
My method is just like what steptoe does, if this does not work I remove the wall
:^O :^O
Nice new plasterboards job done.
Not a method for those on a tight budget though:^O
jibspark
Electrician
Oct 16, 2008
425
old style false wall. wood accross joists with plaster over. touch plaster and it usually parts from wood
that sounds like a nightmare, how would i know it when i see it?
Aug 22, 2008
1,104
6
I just cut out a square between the two uprights. I then put in a batten to fix a metal box to, then I cut some plasterboard the same size as the hole, with a hole for the box of course. Then I use one coat plaster to smooth it all off. I'm able to lay my hands on lots of odd bits of plaster board because my brother is a general builder and is never short of off cuts.
Feb 27, 2008
11,034
Bet he's glad to get rid of it too now you can't throw it in a skip.
Batty
sarni31
Feb 2, 2009
189
Just done a real ball acher :_| :_|
converting surface mount singles into flush doubles... one of the bedroom walls just disintegrated .. :coat
the dodgy over painted filler should have been a clue :eek: :O
I ended up cutting out a narrow rectangle between two joists, fitting new plasterboard and skimmed it up as well. :| :|
customer seemed happy ...
think ill try Steptoe s expanding foam idea next time ! ;)
Guiness Drink
