Hi all,
I've recently installed some outside lighting points, with LED bulbs, which are controlled by a stand alone dusk until dawn sensor. 3 x wall lighting with GU10 LEDs and a spotlight with built-in LEDs. This light in particular has been temperamental since being installed, coming on intermittently. I've carried out some testing and it appears that issue is with the dusk until dawn sensor. I've been informed by the supplier that, with the bulbs being LED, a contactor needs to be used for them to function correctly.
I haven't actually wired in a contactor before and wondered if someone might be able to give me a heads up as to how it should be wired. It's a CPN contactor (MODC2/20).
I thank you in advance for your greatly appreciated help
