check connections, check bayonet fitting, assess usage.One particular ceiling light fitting. the bulbs blow very frequently, any suggestions as to problem?Thanks
Concur with that one M8!Frequently cheap light bulbs blow after short usage, try a decent bulb if you've not already.
to give the lights the benefit of the doubt...thanks all, the light fitting is a 3 lamp fitting, not enclosed and they probably are Cheap lamps but they blow on a weekly basis, this surely cant be down to quality?
eh-- watch it!!!Indeed, Welcome to the forum, Tufty.
You did that pushy shovey thing to me. You are only allowed to do that to KME. X(B-)eh-- watch it!!!
sneakin upbehind me like that!!!
you'll give me one of me turns...:O
:| :_|
LOLYou did that pushy shovey thing to me. You are only allowed to do that to KME. X(![]()
are they on a dimmer ????thanks all, the light fitting is a 3 lamp fitting, not enclosed and they probably are Cheap lamps but they blow on a weekly basis, this surely cant be down to quality?
Register today and take advantage of membership benefits.
