lighting connections
ichinen
Oct 8, 2008
42
Hi, I need to make a lot of connections (ceiling standard...) and the hole I need to fit the junction box (choc) into the ceiling won't allow me to fit the lights hiding the hole (and fitting the braket as well). What's the smallest way to make that king of connections? Any suggestion?
This must be a teeny light fitting if the hole for a chocbox is too big ... how big is it ? The WAGO boxes are small enough to pop through the hole for a downlighter so are these fittings even smaller ?
Yeah, the diameter is 4cm. It's a tiny spotlight... is there any kind of "in line" connection?
Hager / ashley do a downlight JB that is handy but dont think its that slim.
What about click plugs?
you could solder the joints then cover with heat shrinkB-)
Guiness Drink
We use these Click fittings quite a bit - very handy. I've just measured one and they're 40mm x 24 mm at their widest - 105mm total length.
