Looking for "Hens Teeth" and/or "Unicorn Pooh"???
SPECIAL LOCATION
Trailer Boy - Electrician.
Mar 28, 2008
14,542
1,208
A customer last week has a halogen 75W PAR20 GU10 that has lamp failed..
One of two lamps each individually controlled off a double gang dimmer...
So I am looking to source LED dimmable PAR20, (2.5 inch diameter), GU10 lamps.....
But from initial "googles" it looks like they could be rare items?
Any suggestions for suitable supplier(s) from the combined wisdom base of the forumbulator??
Cheers gents/ladies.
What is the original lamp doing?
A lot of those are used as a "heat lamp" to keep something warm, if so swapping for an LED might not give the result you want.
Part of a set of kitchen ceiling lights, supplied by the "kitchen fitters" approx 15 or 20 years ago..
Kitchen is in two sections.. Each section has five recessed downlights in a typical 'dice No'5 layout'..
The two centre lamps are the PAR20 75watt halogens switched from a two-gang dimmer..
Then the two groups of four lamps around then are standard 50mm GU10's off standard two-gang switch.
The bog standard 50mm GU10's have been swapped out for LEDs..
Now the one PAR20 has actually failed..
So was looking for an LED replacement, that would offer some actually light over the kitchen table rather than heat!
Plus to complicate things, they need to be dimmable!!
The original arrangement had 8x50watt & 2x75watt Halogens (550watts of 'kitchen lights'!!)
I was hoping to get the whole lot down to around 50w to 70watts max?
Well for the time being a normal 50mm GU10 would go in but might look a bit lost in the larger fitting.
Consider changing the fitting. You can get fittings that take standard size GU10's that are made to fit an over size hole.
After further searching I have found some LED PAR20, GU10 base lamps on Amazon & another on-line lamp supplier...
But none are dimmable..!!
So I am now considering just getting another 75watt, Halogen Par20, as they are still available..
and leaving the "LED" issue as a problem for another day.
It's becoming too much hassle, for what should have been a simple faulty lamp replacement.
plus I'd need to convert the dimmer switches as well!
Just as a further side note straw-poll....
How many others on the forumbulator would agree that PAR 20 lamps are not a very common light choice, especially within a domestic installation?
I've been self employed since Feb 1999, and this customer is the only one I know with PAR20 GU10 lamps!!
Also I've been doing various jobs for this customer since 2001.. Total invoice costs currently exceed £12,300+ over the years..
So I don't want to stitch-them-up or short-change-them, as they are good customers who no longer ask for a quote or price up front.. They just text or phone me saying; "When can you come to sort out "A", "B" and "C" that are no longer working?"
So in this case sticking with Halogen seems to be the best solution...
As swapping the light fittings could mean they no longer match the other eight standard 50mm (PAR16) GU10's in the rest of the kitchen!!!
AND... (side note#2)
Does everyone else also find that 99.999% of customers still only ever talk about lights as by their Watts rating?
With absolutely ZERO understanding of; Lumens, Kelvins, (Cool / Warm / Daylight), Beam angles, Dimmable-Non Dimmable ?
lighting used to be so much easier years ago!!
