So,
What would you do?
Domestic.
No main water bond can be identified.
Water enters under sink at rear of property in the middle (ish).
Internal stop tap there.
15 m run around the exterior of the property to the CU to put a bond in.
CU under stairs toward, but not at, the front of the house to one side.
Gas boiler adjacent & I mean adjacent to CU about 18" away in a straight line as installed by BG (!) under the stairs.
CU & water about 6m away from each other as the crow flies.
All downstairs.
No easy access through the house, fitted kitchen, tiled walls all fitted carpets upstairs.
Boiler cross bonded (even though all pipes are terminated in a metallic plate, Worcester Combi) in 4mm, gas bond below CU in 4mm adjacent to meter.
TN-C-S/PME single 100mA up front RCD.
Have to make changes to upstairs socket circuit on a 15A radial need to extend the cct.
I will do this job 3rd week in June, I am posting as a constructive discussion exercise, as I am not looking for advice, I have a solution, which I will not post until the thread is exhausted, and, hopefully this will not turn into a slanging match!
I have done similar before, and as it happens my AE has inspected them and was happy with my solutions.
So, please, can we politely discuss & debate the options here as a learning exercise?
My materials list is already done and quote sent to the customer.
I am not going to post the reason for the changes, suffice to say it is an extension to the 15A radial socket circuit upstairs as it may cloud the issue.
Overload of the mcb not an issue.
The wiring in the existing cct is 2.5mm sq and the existing Zs is well in at the end of the radial and will be well in within the modification.
All modification wiring to be surface mounted in trunking.
100mA RCD up front.
Al circuits mcb protected.
What would you do?
Domestic.
All downstairs.
100mA RCD up front.
