MCB Lock Offs...
i dont have any idea of the offical answer, nor do i really care for it that much, but heres my tuppence worth...
to isolate a circuit requires the live to be disconnected and locked off, a NEUTRAL is also a LIVE
to do it properly would require a DP MCB,
to do it practically would be the SP MCB we all use, as the main switch means killing every circuit thus causing untold inconvenience,(even in a household, never mind offices/factories etc.)
One has to draw the line somewhere:
DP would be best.
SP we normally accept as safe.
But we should always check for live, regardless of locking off.
I see that when you buy a square D three phase dist board they throw in a free mcb locking toggle......they only recently started this as they have apeared in my last 2 or 3
Now I seem to have read in the new bible, that if the system is TN, the neutral can be taken as being at earth potential; therefore only requiring SP disconnect.
As long as I`d tested polarity, I would personally only isolate at the MCB.
IMHO for what it`s worth.
