Melting bitumen
ecasam
Feb 26, 2008
76
South london
Hi everyone, hope you are all doing well. :)
I was at a house the other day and the head was dripping very slowly. The bitumen is melting, wet to the touch. I told customer to call supplier.
Has anyone ever come across this before? What is this a sign off?
Usually a sign that a lot of things are being used so supply is being worked well. As Andy says call Dno they should change it.
Batty
I agree with the comments so far.
Bitumen only "leaks" when raised to a melting temperature, so it would suggest some heat is present causeing the bitumen to melt, this can only be attributed to a loose connection.
Do as the other posters have suggested, and it will be taken care of
