Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrical Photo Forum
Metal case, fire-proof dimmers could be the next thing!?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="SPECIAL LOCATION" data-source="post: 435816" data-attributes="member: 250"><p>Are those the ones where the warranty is only valid while the product is still unsold....</p><p></p><p>i.e.. once you remove the said item from the retail outlet any warranty is expired/useless/worthless/only valid for pink unicorns wearing tartan football boots singing "the deadwood stage is coming over the hill"?</p><p></p><p> <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite7" alt=":p" title="Stick out tongue :p" loading="lazy" data-shortname=":p" />opcorn </p><p></p><p>P.S. I fitted a bog standard double gang switch and also replaced another dimmer switch as the customer was a bit worried and concerned about dimmiers..</p><p></p><p>The one that caught fire was working 4x Gu10's.. didn't look at them all but 4x 50w should be within the scope of the average 250watt dimmer.</p><p></p><p> :C</p></blockquote><p></p>
[QUOTE="SPECIAL LOCATION, post: 435816, member: 250"] Are those the ones where the warranty is only valid while the product is still unsold.... i.e.. once you remove the said item from the retail outlet any warranty is expired/useless/worthless/only valid for pink unicorns wearing tartan football boots singing "the deadwood stage is coming over the hill"? :popcorn P.S. I fitted a bog standard double gang switch and also replaced another dimmer switch as the customer was a bit worried and concerned about dimmiers.. The one that caught fire was working 4x Gu10's.. didn't look at them all but 4x 50w should be within the scope of the average 250watt dimmer. :C [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
