Microwave starts going around when you plug it in
Neil Jackson
May 21, 2020
Starts working without You pressing anything. Plug in and off it goes. What could be the cause of this is it to do with the digital part of the microwave? Any ideas would help wife going into meltdown as used it to make milky coffees
Hopefully it stops on the door interlock?  i.e doesn't do ANYTHING if the door is open.   If it does (do anything) then don't plug it in as it could be dangerous!
On the few microwaves I've repaired there is a bank of relays on a printed circuit board all controlled by the microprocessor and operating the various functions.
Most likely the relay controlling the turntable has failed on yours.
Unless you are competent in electronic repairs there is nothing you can, or should attempt, to do except go and buy a new microwave.
Microwaves are the most hazardous domestic appliance to tinker with; be warned!
As the above two posts. Microwaves can be very dangerous if taken apart . There is a component that is extremely dangerous. Again - be warned.
A quick Google.
Magnetron, Move Over!
Magnetrons can be incredibly dangerous, while you are safe from radiation when they are not powered, the ceramic insulators can contain beryllium oxide which can be fatal when inhaled. If Magneto is the enemy of the X-Men, the magnetronis the enemy of all lungs everywhere.25 Jan 2017
