minor work certs issue
moose man
Aug 8, 2009
510
Do you have to be part of a scam provider to issue a minor works cert only. If your a compedent person
thanks moose man
hi moose,
I think as long as it's non-notifiable you can issue minor works cert.
hi sparky b
it is non-notifiable as the work was carried out in a upstairs bedroom addition to exsisting ring final
Mooseman,
LIKE the avatar mate!
You are fine to issue MWC, EIC & PIR as long as you are competent to do so.
The ONLY stumbling block comes up with respect to Part P notification.
PIR does not need to be notified.
EIC & MWC type work only requires notification if it comes under the notification requirement of Part P.
So unless it is notifiable under part p just get on with it!
Thanks for that sparky b and sidewinder havent got a thanks button now
moose man
