hi chaps,
Q1. if you were changing a pendant for a new metal fitting in the middle of a lighting circuit would you need to find the end of the circuit to do the R1+R2 for that circuit or would you just ensure earth continuity at the light you were changing.
Q2. also if for example you were changing a consumer unit and you need to get the R1+R2 for the lighting circuit and there was a chandalier as the last light on the circuit would you have to take it down or could this be taken from the .
Q3. also how do you locate the last light on the circuit
cheers
cheers
