phil d
Ok so as you know I won those holesaws in the Armeg competion, so having given them a try I thought it was time to do a bit of a review of them.overall they are very good, it's a bit strange when you look at the cutting edge and then send it into a piece of steel trunking, it really doesn't look like the type of thing you'd use for this, the tooth set up looks nothing like a 'normal' cutter, but it does the job easily enough and no snatching when it goes through. The one thing I would like to see however is a 'stop ring' on the back of it, like on the earlier models, it's quite handy when you are drilling into a trunking with cables already in it. I can't comment on how it performs in other materials as yet, but so far so good. Thanks Armeg.
