Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Neutral/Earth leakage
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Barx" data-source="post: 38084" data-attributes="member: 121"><p>An RCD WOULD trip if neutral and earth touch. An RCD works by monitoring the phase and neutral for differences (under normal use neutral current = phase current) If the neutral and phase currents are different then some leakage is present and so something is wrong......trip goes the RCD. So, if neutral is leaking (touching in this case) to earth then more current is flowing through neutral then phase and so your RCD tripped.</p><p></p><p>Hope that makes sense.</p></blockquote><p></p>
[QUOTE="Barx, post: 38084, member: 121"] An RCD WOULD trip if neutral and earth touch. An RCD works by monitoring the phase and neutral for differences (under normal use neutral current = phase current) If the neutral and phase currents are different then some leakage is present and so something is wrong......trip goes the RCD. So, if neutral is leaking (touching in this case) to earth then more current is flowing through neutral then phase and so your RCD tripped. Hope that makes sense. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
