No Mate, You sleeve the black - Red. at both. And if you are adding new colours to the old, then you need to add the warning sticker to the CU.do i have to sleeve old red and black cables in the switch and light fitting to brown and blue if i add an extra light to an old fitting?also what is the correct method or material to use? ?:|
Welcome!thanks for the speedy reply.just to clarify the switch cables are double red+earth and a single red+earth so i sleeving is not required?
if i alter the wiring in my bathroom would it be advisable to run a new t+e to the cu and terminate on the rcd side of the cu. the cu is a memera 2000. the rcd is 30ma and there appears to be to 2 free spaces to the left of my ring main. the upgrade in question is a power shower. if i do decide to install a new shower can i use 1.5mm to feed the pump.
Part P applies to England & Wales, you will need to find the equivalent regs from your local building control, irrespective of what was allowed on previous regs you must comply to current version for your territoryhere comes the crunch. bite the bullet and all that i have been installing alarms and cctv as the last three years and believe i am a competent person.
wiring the shower as a spur from the sockets gives my shower rcd protection
but what about the rest of the bathroom or are you suggesting taking a 2.5 t+e to a switched fcu in the roof space and the wiring the bath room from the fcu.?
spur from a socket is handy as i have a single socket in the landing on the outer side of the wall where the proposed shower unit will be mounted.
the house was built 11 or 12 years ago did bathroom zoning exsit as this socket was less than 3mtrs from the bath.
if i also fit a low voltage light what would you recommend i do in order to fit the cabling for the fan that allready exists in the ceiling rose. the light my good lady has bought has only a small 3amp connector block for the feed cable
does any body know if part p is applied in northern ireland
thanks for your time
Trade of between cost and convenience, but it's no longer acceptable to wrap terminal blocks etc in insulting tape, preference is to go for zero maintenance push types e.g.thanks very much green hornet.what is your thoughts on junction boxes. traditional type or the new fangled push connector type?
I think so.thanks batty i looked at the wago link provided by robijin, looks like a good system.
"aint it just nice to be nice"
