Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrician Talk Forum
New Build Heating
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="steptoe" data-source="post: 154766" data-attributes="member: 7"><p>ground source is OK if no one else for about 500 miles has one, ... LMFAO</p><p></p><p>air source JL should be good unless you are fitting AC units that have been converted, have a check and see.</p><p></p><p>other than that I have went other as I reckon you need a combination,</p><p></p><p>air source, Solar PV and preferably oil if available(if not then gas) with a wood burner if possible would be my ideal.</p></blockquote><p></p>
[QUOTE="steptoe, post: 154766, member: 7"] ground source is OK if no one else for about 500 miles has one, ... LMFAO air source JL should be good unless you are fitting AC units that have been converted, have a check and see. other than that I have went other as I reckon you need a combination, air source, Solar PV and preferably oil if available(if not then gas) with a wood burner if possible would be my ideal. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
New Build Heating
