charliefoy
Hi, I've just moved flat, and it is heated by electric heaters which I have never used before. After researching electric heaters I have found that most of them have an Input/Output control, however I am having difficulty with learning the best way to use the heaters in my flat as I only have one dial and what appears to be a thermostat or timer. The thermostat/timer is rotary and has small notches which have two available positions. There are two other switches next to these controls too; Any help would be greatly appreciated in regards to using the heater properly and efficiently, thanks. (there is no brand name or model on any of the heaters, they are all the same throughout the property)
(tried to supply photo's but I don't have enough posts, can pm photo's if needed)
