NICEIC Assessments
maccarooni
Jul 13, 2008
339
can some tell me what to expect on a first nic assessment, all info gratefully received. they have told me ,2 jobs, copy of certs, insurance etc, but i would like to know more, they are sending me an info pk or something. thank you all in advance
Macca
Guiness DrinkGuiness DrinkGuiness Drink
this thread is sort of a follow on from my previous one
Are you being assesed as a domestic installer, or approved contractor?
I am assuming DI, as they normally ask us for 5 jobs (approved contractor).
Generally, the day goes as follows.
Engineer arrives at your house/business premises.
Wants to see ALL your H+S policy, public liability, complaints form, etc.....
Then wants to see your issued certificates to date.
He normally picks two, that he`d like to see, and you `phone customers to confirm they`re ok (I normally forewarn customers that I`m regularly assessed, "to check I`m doing my job properly").
If they aren`t in/ inconvenient, he`ll pick another.
Then he jumps in your motor, and you go to the jobs.
He`ll want to see you performing the tests, and getting approx the same readings you put on your cert.
He`ll ask a couple of questions (remember - he ISN`T trying to catch you out - he`s making sure YOU know what you`re talking about).
Most inspectors are practicing sparx - If you want to know something technical, they`ll usually help.
word to the wise - when he arrives, be prepared. Offer a cuppa, and be ready to discuss what work you`ve done recently, eyc.
I apologise if I`ve rambled, but, as the regulars will know, ............
KME`s Guinness Guiness Drink
has been assessed in detail this evening. (hic)
Hope that helps mate (FYI, my annual assessment is the end of the month - and I`m going to be flat out between now & then, so he`ll have to take us as he finds us:OPray
(At the end of the day, it isn`t financially viable for them to fail you; unless you appear incompetent!)
Brush up your regs, and be prepared for a live version of 2381, 2382 and a bit of 2391 thrown in.
Don`t try to waffle or bluff!!!! If you don`t know the answer to a question, say so. Much better than appearing to be a pillock.
Excellent advice KME - I assume the assessment done by Elecsa is pretty much the same? Must admit, I've been a tad nervous about my pending one, but have recently done lots of testing and feel a bit more at ease about it. Just need to book it now!Pray
I would expect so, AAL
No need to be nervous. As said, they don`t try to catch you out. Imagine instead that you have this lecturer-type person, who can answer any questions you have.
You`ll be fine;)
KME
thank you for you're input, sorry for not replying sooner.
Yes it is a DI reg i have applied for. Officially I've only done two jobs so far (and 1 of them is at home).
I've worked for a NIC registered co for 7 years and want to build up my own base.
I have 17th edition and 2360, also at the moment doing the 2391, although as far as I'm aware the latter is not a requirement for registration. I hope to have my assessment within the next 8 weeks (Apparently according to nic ) so again its another case of waiting to see.
Many thanks again KME. I will try to get organised
Macca
By the way the Guinness is good.
Morning Avin, I had my Elecsa assesment last friday KME might as well have been with us because he was spot on with his post, I got 1 non conformance and have 45 days to provide photographic evidence that it has been rectified, you have a scale of A,B,C
A, straight pass
B, non conformance, provide evidence then pass
C, fail and a recharge to come out again.
you need the big red book, small red book ( OSG ),public liability,H&S, complaints form ( these are sent out by Elecsa prior to the visit )
hope this helps
NWDS
Most be DI? For Installer the first visit is the pre inspection?
Thanks for that, but I'm sorry i don't understanddo you mean I am havindg a pre inspection?.....What and how is this different to an assessment.
Macca
Well thats good to know,,,,,,Guiness DrinkGuiness DrinkGuiness Drink
Macca
