So, did you tick it?Had to do installation test today and used a 17th. Edition Installation Certificate nearly the same as the old ones but on the schedule of tests there now is a box to tick verifying that you have checked volt drop CJS
Only if the supply is from a public LV distribution system.3% on lighting, isn't it? And 5% eleswhere?
Tell him that he is daft as it is on page358 of the BRB appendix 12.Do you know what Sept. I had that question in my 205 exam and I told the lecturer that they were higher for a PLV Supply.He don't me not to be daft as they were the same. I told him that I saw them on my 17th ed OSG. (didn't have it on me at the time).
same here. and probably got another few months till i need to get new bookslike me still using the old ones up .
i have been told be elecsa that i can continue to use 16th certs, just to make sure change 2001 to 2008The 17th Edition certs are different though. The schedule of inspections is completely different, Polarity check is on the results page and a few more i cant remember. You shouldn't be using 16th certs.
The 16th edition forms do not have the necessary information.lets get one thing right a certificate is a piece of paper for recording the results and schedules and other information, as long as the cert has the necessary information it doesn't matter where it is on the form. you could use your own made up cert as long as it had the relevant information on it, which you could copy off the regs book .
using 16th regs cert or 17th they both require the same information.
Keithcould you please tell me what they are lackingIf you say the bit about verify volt drop that is only a nic thing and the regs
Register today and take advantage of membership benefits.
