Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrician Talk Forum
Nlsh24An Storage Heater
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="rockomuir" data-source="post: 338944" data-attributes="member: 4123"><p>Hello all,</p><p></p><p>Trying to fix the above storage heater, and was just t wondering if the thermal cut out was manual reset or it needs replacing. I believe it was a manual reset but when i push down on it there is no click and heater does not work. If i put a screwdriver on the little metal that is sticking up and push it down the heater works. I have checked continuity on elements and input and output stat and they are okay, I have enclosed a picture if anyone could give me a little advice.</p><p></p><p>Many Thanks</p></blockquote><p></p>
[QUOTE="rockomuir, post: 338944, member: 4123"] Hello all, Trying to fix the above storage heater, and was just t wondering if the thermal cut out was manual reset or it needs replacing. I believe it was a manual reset but when i push down on it there is no click and heater does not work. If i put a screwdriver on the little metal that is sticking up and push it down the heater works. I have checked continuity on elements and input and output stat and they are okay, I have enclosed a picture if anyone could give me a little advice. Many Thanks [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
