Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrician Talk Forum
Noise From The "off Grid" Heaters
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="binky" data-source="post: 374992" data-attributes="member: 490"><p>Power One is part of ABB group, not famous for being cheap sh1te. It converts from dc to ac using high frequency galvanic isolation. Power one used to have a function whereby you could re-set the frequency it operates at to gain a slight increase in efficiency, they are normally set to a range which is inaudible. If the inverter is somewhere you are unlikey to hear it, changing this setting will change the frequency of operation, which may solve your heater issue. I tried this on my own inverter and could hardly hear it from 2 feet away.</p></blockquote><p></p>
[QUOTE="binky, post: 374992, member: 490"] Power One is part of ABB group, not famous for being cheap sh1te. It converts from dc to ac using high frequency galvanic isolation. Power one used to have a function whereby you could re-set the frequency it operates at to gain a slight increase in efficiency, they are normally set to a range which is inaudible. If the inverter is somewhere you are unlikey to hear it, changing this setting will change the frequency of operation, which may solve your heater issue. I tried this on my own inverter and could hardly hear it from 2 feet away. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
