Old Bones
PaulSC
Sep 23, 2010
102
After my last job whacking out solid brick by hand for numerous back boxes, I've realised I'm not as young as I used to be :C
I've searched the forum and found a few useful bits, but I'm going to ask the question anyway.
I'm NOT going to buy a box sinker, as it would have disintegrated on this last job. I going for a SDS with rotostop (my current Ryobi SDS only has drill and hammer settings) together with an SDS scutch chisel.
Question is, I'm on a bit of a budget and wonder does anyone know of any good deals or gear they would recommend?
Appologies if you're sick of answering this type of question - just ignore it.
i wouldnt buy the box sinker either. i have one but it rarely gets used because its not much good (not even kept in the van)
SDS & chasing bit is all you need
even the
Agreed. The Bosch is a good deal (as we`ve mentioned recently, there is a 3 yr warranty (online) for the bosch stuff - well worth the money. 6Kg is way too big for what you want, IMO
KME
I'm not trying to change your mind but I have just spent the best part of the day 1st fixing, which included a number of 2 gang and 1 gang boxes installed with the
yes you guessed it,
the box sinker.
Works fine for me, although this was a new build so dust was not an issue. And they are dusty!
I'm not trying to change your mind but I have just spent the best part of the day 1st fixing, which included a number of 2 gang and 1 gang boxes installed with the yes you guessed it,
the box sinker.
Do you use the ARMEG box sinker or another different make?
---------- AUTO MERGE Post added at 21:04 ---------- Previous post was at 21:02 ----------
i know you said you dont bother with the box chasers, would the 2kg be ok for those also.http://www.screwfix.com/search.do;jsessionid=EP1LNUJ40MH20CSTHZOSFEY?_dyncharset=UTF-8&fh_search=68064, what about this one
Thats a 6kg one too mate:D
Do you use the ARMEG box sinker or another different make?---------- AUTO MERGE Post added at 21:04 ---------- Previous post was at 21:02 ----------
Armeg Matty.
Works for me but as I say it's dusty.
and tom, if you want something heavier for chasing, you can borrow my 18KG drill. good luck holding that on a ladder though! (and try not to take down the wall)
ar pi##s
i ment this one
---------- AUTO MERGE Post added at 21:15 ---------- Previous post was at 21:13 ----------
omg i will type the link in by hand in a min
cant do it, its the dewalt 2kg with drill driver
83908
I can't beleive people are still chasing in boxes by hand, makita roto stops only 120quid. I'm sure you could price that into a re-wire.
Would toatally agree pro dave, with one small exception in that I would look for a unit with safety clutch having once nearly twisted a finger off. Think the Erbaur falls into that category and has long warranty service, which I have found to be excellent in the past.
