Old MK Grid
Tim Howard
Sep 8, 2024
67
112
Oswestry
I'm sure someone instantly knows...
I have an old style 2 row mk grid box, with 3 switches on each row...the old sort with the metal clips top and bottom.
To best of my knowledge these modules are now only available 2nd hand so I'm looking to change all 6 switches.
Do I need to change the surface mounted box, or is 2 new frames, 6 new switch modules and a new front sufficient?
(It's a surface mounted box)
TIA
I had a similar problem to solve with an 18 gang MK grid switch about 5 years ago, the cost of completely replacing that for a couple of failed switches was going to be astronomical so swapped a 2 gang grid switch elsewhere in the building for a new grid switch to get the switches I needed for the repair to the 18 gang
Thanks - trouble is I did that last time! I don't think I have any old style left now.
