Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrician Talk Forum
Old UK Cables
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Sparks 44" data-source="post: 485762" data-attributes="member: 31757"><p>Hi Guy's &amp; Gal's</p><p></p><p>Anyone familiar with an old wiring cable used in the Uk or particular around Peterboroughs Welland Estate as I know it was used here also, possibly in 1970's its almost a twin and earth in the way that it has solid core pvc conductors however instead of being encapsulated in a pvc sheath separated by chalk during manufacture this is a black hard rubber outer sheath where the single core pvc conductors run loosely within so they can actually be pulled through and replaced. I have a customer who's installation still uses this cable and was wandering what British standard this cable was manufactured too,anybody have a clue. Thanks</p></blockquote><p></p>
[QUOTE="Sparks 44, post: 485762, member: 31757"] Hi Guy's & Gal's Anyone familiar with an old wiring cable used in the Uk or particular around Peterboroughs Welland Estate as I know it was used here also, possibly in 1970's its almost a twin and earth in the way that it has solid core pvc conductors however instead of being encapsulated in a pvc sheath separated by chalk during manufacture this is a black hard rubber outer sheath where the single core pvc conductors run loosely within so they can actually be pulled through and replaced. I have a customer who's installation still uses this cable and was wandering what British standard this cable was manufactured too,anybody have a clue. Thanks [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
Old UK Cables
