Background:
I got a 4kWp (16 * 250W PV modules) installed facing south on my main roof with FiT since 2016 on residential.
Today:
I want to install more panels as I have other location (facing west, south and south-west) where 9 panels could fit + I want batteries that can be charged by the new panels AND the existing ones.
I want this new system not to interfere with my FiT.
I understand that I will need a new inverter for the new 9 panels. In order to keep my FiT, the existing panels cannot be connected directly to the battery as this will bypass my generation meter. Therefore it has to go through my existing inverter (conversion from DC to AC) and then be converted again to DC to feed the battery. I appreciate there will be some loss but at least I can keep FiT
Now the original proposal was to have 9 x 395W panels which gives 3555W. However, I could install different panels and reach 4725W which is about 33% more.
My question after this long intro (sorry) is what does that mean in terms of DNO.
I have read that for above 4kW (16A x 230V single), there must be a DNO approval, however, I have also read if there is a second inverter it will not be necessary. This said, if it is correct that if I have a second inverter (which will be the case) I do not need DNO approval, it could be that I must be limited to 4kW max as per a standard household installation.
Obviously, I am keen to get the most of the pace I have and as mentioned, I could go up to 4725W. Would that then mean that I need DNO approval for the new system at 4725W and need to move to 3 phases (4725W + my existing 4kW). If so, how can I find out if it is worth the cost? Should I better stay with a single phase system and having 2 investors allows me not to go through DNO approval.
I have spent days trying to understand who to contact and DNO seems to be an obscure thing. The installer I selected has made a request but he said it will take weeks.
so I am trying to find info to see if we pursue the effort to develop the optimal system for the space available, or we better stick with a 4kWp system (ie having 2 4kWp with 2 inverters (one installed in 2016 and one to be installed).
I hope I have given you enough info and that someone will be able to point me into the right different to find the info I need.
Thank you very much in anticipation
Bob
I have split this post to avoid confusion
Today:
Bob
