Outbuilding IP ratings
nah - we've had this before. Unless you feel that the accessory is particularly likely to get wet then you may choose to.
Some members favor metal clad accessories as they stand up to a bang from the lawnmower or ladder better!
I'm with patch on this, it really depends how 'weatherproof' the shed is, but an important consideration is the likely damage from knocks etc.
I have done a few concrete garages and would put the hamilton IP rated ones in these but wooden sheds don't tend to condensate much. Tin sheds are another thing though.
Batty
HelloDo you need IPX4/5/6 rated sockets/lights for an installation in a shed?
Many thanks,
James
depends who built the shed...
and if you can have pic below outside, i dont think you need any IP rating in the shed...
depends who built the shed...and if you can have pic below outside, i dont think you need any IP rating in the shed...
What did they do, move the house?
I normally use standard accessories, but I do like to fill any openings with silicone to prevent insect ingress / helps with condensation. Metal clad only if likely to get knocked.
