I installed an IP66 outdoor socket on the wall of my garage (outdoor side), to supply the water pump for the garden vegetables.
This socket it's powered on/off by a wall mounted switch, IP44, installed inside the garage, so the socket is normally powered off.
Checked, all works well as intended, so far so good.
Issue is, the switch has a little red LED on its front, to indicate the status. This LED is always off. Although everything else works good.
What did I do wrong and how to fix it?
Thanks,
Thanks,
