Hi Guys. Got a job on tuesday to supply two separate Miele ovens. Each oven is 3.6KW and because of the logistics of the kitchen I am going to use the existing 32 amp (6mm cable) supply which originally supplied the previous oven. The job was prepared before the ovens arrived with the information I had been given. The manufactorers instructions are to fit a fused connection unit or a double pole isolator. The connected flex from the ovens is 2.5mm.
The max load of the ovens is nearly 16A each. Therefore 13A fcu's would be insufficient and the 32A MCB at the c/unit would not protect the ovens. Your advice and thoughts would be most appreciated. I know that manufactorers spec supercedes the red book.
I
I
