Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Oven tripping RCD
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Doc Hudson" data-source="post: 485914" data-attributes="member: 1607"><p>Is the RCD dedicated purely for the oven circuit? or do you have one of the all to common cheap and nasty dual RCD boards with multiple circuits sharing the same RCD? Dual RCD, multi circuit per RCD boards can have circuits that are switched Off, able to trip the RCD due to common neutral &amp; earth paths which any one of the other live circuits can flow down to cause the RCD to operate.</p><p></p><p>Doc H.</p></blockquote><p></p>
[QUOTE="Doc Hudson, post: 485914, member: 1607"] Is the RCD dedicated purely for the oven circuit? or do you have one of the all to common cheap and nasty dual RCD boards with multiple circuits sharing the same RCD? Dual RCD, multi circuit per RCD boards can have circuits that are switched Off, able to trip the RCD due to common neutral & earth paths which any one of the other live circuits can flow down to cause the RCD to operate. Doc H. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
Oven tripping RCD
